  • Replies 55
You want someone with a matador/Bedford type with a big winch on or I like the dig a hole and bury it idea mate :thumbup:
Hi mate Steve mate has a large high mac with splitter thats the one for the job jon
10 kg of semtex..... & a reliable moto-x bike to get away on!!!!!!!!
If you are trying to put it into orbit, a couple of hundred grams will rip that from base to apex.
got a really big storm damaged beech to cut up and the stump is going to be in the way for builders that are coming to fix a retaining wall..so need to be moved.
Its a massive stump and i reckon it will weight 2 tons. Access in bad so no crane.
Any ideas?
this or this
If you can sever the stem and allow the stump to fall back into the hole, then grind as normal. Ypu may need a winch / digger to encourage it to go the right way. I'll second the 10 ton weight btw
