If you mount them both beyond the rear axle you will muller your rear springs and be overloaded on the rear axle.
If the Austrian test is as severe as I remember they will fail it on sight. Anyone reputable will tell you this before they build your white elephant.
  • Replies 48
why mount it on the body?
could you lift a chipper in and out with the crane and even use the crane to tip the tipping body therefore dispensing with tipping gear too?
Could you not mount a crane to the chipper? The hydraulic capacity may be a problem though, but a chipper running at working speed, could it run a crane if it was feeding two pumps?
If you were going to stick a chipper on the pto of the wagon, go for a pto greenmech cs100, only needs 20hp!
Would you crane feed a cs100??:confused1:
I have been thinking about the idea of mounting a crane and chiper onto a lorry . Would it not be possible to buy a 10 ton lorry to mount the chiper & crane to and then aply to register as either specialist plant or to apply to have it registered to a restricted load ?
10 ton lorry, mount a bandit 250 so it can swivel to the side then mount a timber grab on the rear, I thought about it but I had no use for it, just would of been cool :)
I mounted my tracked chipper on the rear of my 10 ton lorry with crane, was far to heavy over the rear, I should of just striped down a tow behind and bolted it on instead.
having a unit you do not need to remove a chipper is great.
