  • Replies 33
Tom what would the average dimension and weight requirments be for said frame?
elg
The bags are 1m x 1m x 1m and when filled will weigh about half a ton but the frame does not need to be weight bearing. It's just to hold the shape of the bag whilst filling.
As has been said, filling them into a static bag results in under filling them by quite a lot (est 25%). We now fill in to the bag whilst its hanging on a round bale handler on a tractor front loader so its just touching the floor. We then shake it at about 75% full & again at 95% till it wont settle any more. The bags are now very solid, square & stable.
  • 1 year later...
Bit of an old thread but do people find using the road pins works quite well? Only got one tractor which runs the log splitter and also the loader with pallet forks so can't fill direct in to bags at the moment, doesn't seem efficient. Even if I could only fill them 80% using road pins then had to top up once I pick up and bounce the bag on the pallet forks it's going to be a lot better than what I'm doing at the moment...
