Where applicable please could you list your chosen application for the knot in question, size cord you prefer, length of cord(or loop in some cases), pros and cons, etc etc...anything you can think of really. Thanks
I only use prussik's if I'm using both ends of my rope - advantage is it works both ways up - unlike a blakes hitch (upside down = suislide knot!) or as a back up for lowering with capstans etc in aerial rescue (6 wrap)
The most basic and generally the beginners friction hitch.
99% of climbers start using this
100% would be able to tie a prusik
The simpliest most versatile knot in the Arb industry
Foolproff
Easy to tie
Easy to identify as tied correctly
Bomb Proof
Β
Although I thought it was spelt prussic:confused1:
  • 5 years later...
Mainly use it when balancing limbs so get the tension on both sides (of spiderleg) equal. 85cm i&i 8mm.
Β
Show it to my groundies as a friction knot to start climbing.
Β
Also use it as friction hitch for setting 2:1 or 4:1 systems.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
