Tom Tom or Garmin
welwell
Bit of advice needed?
I'm going to buy a satnav, and wondered what your views are on the two main players in the field. They both seem to offer similar specs, but is there a better make out of the two or is it the same as the eternal Sthil v Husky debate???? I'd quite like Bluetooth as an option.
Thanks for the advice peeps.
  • Replies 23
Tom Tom are fine if plugged in to power supply all the time but if you don't use it for a couple of months even if you put it away fully charged it never wakes up again!! I've had two and both died in the same way, I contacted Tom Tom and they said that was a common fault they need constant use.
That's not so good!
