Guys when you rig heavy limb sections with no branches ie smooth what hitches are you using
Personally i use a half hitch then a timber hitch the half hitch guides the section and keeps it inline.
I do sometimes worry that it could slip through under a big shock load as somtimes i cant avoid shocking loading.
  • Replies 85
You could use a marlin spike in place of the half hitch....you could also use a running bowline where the timber hitch ties up.....personally I use the runnin' bowline only if I can hitch it up against summat `( a stub, swelling WHU )
marlin spike- surley that is weaker than a half hitch due to the tighter bend of the rope? I'd not recomend it.
As for not using the running bowline- can you say why
Actually....as the loads are increased, the knots are probably tighter or tightened....snatchiung is another issue altogether.....I read of occasional failures when using the timber hitch....
