Agriculture Land use and Planning Regulations
wildwood-dwt
we had an agricultural smallholding and have had to have full change of use for the part which is the timber yard, it can cost for planning application about £300, if you need someone to work on your behalf etc as we did and submit plans and draw up what needs doing it could cost about another £400, all in all it cost us about£1k but were legal now and can do what we want. if you can prove you ve been their 10 years with no complaints that can make the process easier. - as storage of timber does not constitute agricultural use as it would not be a crop grown or harvested from said land, get planning and then your covered.
If you have over 12.5 acres you are classed as a Farmer and can get away with almost anything and probably get a grant for doing so and have the right to moan about how little you earn from it.....! Allegedly :001_tt2::001_tt2::001_tt2::001_tt2:
is that true or are you being sarcastic
if you have a registered holding of 12.5 acres + the government decided that you could make a living off 12.5 acres minimum thus classing you as a fulltime farmer or having a proper farm as opposted to smallholding, we are a smallholding as all our land is not connected and some is rented. the 12.5 acres i believe was set as this could support an intensive farming practice such as eggproduction or pig set up. this then could enable the owner/farmer to put in planning for biulding of a dwelling to enable farmer/farmworker to oversee animal husbandry etc. and so live on site as the farming practice would justify 24hr monitoring
I don't think the land being rented makes any difference.
