Jensen have just made a 750 kg unit just for the uk market. It has a 30 hp kubota turbo engine, braked chassis metal light board, folding hopper. It is shorter than the standard A530DI. So it is a very compact unit and has all the heavy duty features of the Standard A530DI.If anything it picks up quicker than the standard unit because of the turbo.
Is it going to be at Saltex or the APF? i look forward to seeing that one.
  • Replies 202
Anyone know these? I'm fitting it on my U900.
Comments, suggestions on weather I should use the 540 or 1000 rpm pto setting?
-I actually had to use the high flow pump for the two hydraulic feed wheels.
I have a CH160 on my U1000.Its mounted on rear hydraulic linkage and I run it at about 1300rpm.
Check the gap between the blades and anvil(s) before you used it.Mine was wide open and blocked alot before I changed the blades for the first time and discovered the problem.
Not sure about that. Do you guys do one?
In our current range we do a sub 750kg machine with a 6x9 inch opening and a 34hp turbo diesel. The turbo thingy keeps the flywheel thingy spinning good. As per usual, it will be at Saltex, APF, Weald Woodfair and available for private viewings!!!
