hi my 066 has died with messing about ive found that the spark isnt right.
Does anyone know the gap settings for the magnito before i take it to shop im going to try resetting to see if i can do it myself.
cheers
  • Replies 25
Use a typical business card and put this betwen the coil and and flywheel magnets then do up the location bolts. Two thicknesses of A4 printer paper will also work.
There are factory tool but this will suffice.
it shouldn't have moved unless loose though.... you tried all the wired etc and checked connections?? also i think 044 coil packs etc are the same?? correct me if im wrong..... you not have any spares lying about??
Had a prob with spark on 066 before, it was the lead from the magneto to the plug. Worth checking? I think it came attached to mag, so expensive repair for what was just a dodgy cable!
