if going for the hitch climber, which is the one to go for? the one with the brass bush or the one with the bearing, are there any pro's or cons for both??
  • Replies 47
Well I went for the red one, brass bush. I didn't go for the rapide, because I'm not very...rapide. Sorry, I'm sure someone else will give a sensible answer.
I recently started using a Spiderjack and im liking it a lot. Where abouts in Yorkshire are you Swinny? You can come have a go if you like see what you think?
well it used to be classed as yorkshire :D i'm over in sunny barnoldswick
Surprised no one has mentioned the Blakes
honestly believe it is the next step from a prus
then ideally you need to get someone to go through VT or mechanical stuff as a lot of finner points and potential for getting it wrong
i do like the blakes also :)
i did but a new split tail and used it a few times but at work use someone else's gear provided and thats prussic, pita when jams etc....
Just wanting to get away from the body thrusting malarky :)
