air spade information
perci
hello, is there anyone who can give me some info on 'air spade', how fast it digs,what's it like to use, is it messy and can you de-compact with it(blasting air in to the ground)? I've got a couple of jobs lined up but they won't pay for it out right. does it tend to spend most of its time in the garage? thanks for any help.
  • Replies 20
Popular Days
I bought one for a job a couple of years ago. The one job job paid for itself (easily). Since then I've used it a couple of times to find buried cables beneath stumps and once to expose some roots so the LA groundworks team could build up a footpath over some poplar roots without severing them. Its tucked away in the back of the container at the moment, maybve I should start to promote it a bit more. It is a messy job but it is also pretty good fun at the same time. I wouldn't think its too good for deep de-compacting jobs, a terra-vent will probably do a better job and it will only loosen the soil (or blow it away to the side of trench etc. To effectively dig you would also need a suction device. Hope this helps and good luck
