Just found out what carcinogenic means ( causes cancer ) can anyone tell me of any that when cut can be carsinogenic please ? Ive heard that laburnham is and also fine sawdust from pine trees ! Is this true ??:001_huh:
But just to show that nature is a thing of many wonders, taxol (as extracted from yew trees) is used as a chemotherapy drug.
Other common sources of carcinogen that might not immediately spring to mind are soot or used engine oil, and burned toast.
london plane, these take in the the fumes from cars . Thats why you find them alot in inner cities. The dust off these is real bad for you...
any work is welcome work
The fine dust from most trees is carcinogenic.
Sad but true . You should also take care when handling fuel and oil as this is bad to . Not forgetting the odd fire and dont mention the saw fumes . :001_huh:
Edited by White Noise
most hoard wood dust is carcionwhatever, so is eating to much carrots, so is sitting on your arse, could be worse you could be a welder - they huff loads of nice fumes every day. If you are worried wear a dust mask - the stress from worry will more likely give you cancer, or the fact that most of the water and food we drink is chock a block filled wit chemicals, or we nuke our food, or that cell phone, i reckon wood dust is the least of your worries - though dont get me wrong you can get a touch of farmers lung from it, especialy chipping dead elms....chough splutter etc...
