Where are you based (with the series 88)?
Id look on ebay but also keep a look out in the local adds papers etc as you can get great bargins.
H
  • Replies 29
Got a land rover 90 which would make someone a good project. Already planted in a disco turbo engine as original was a slug. Chunky off road tyres all round body work needs attention especially around front windscreen. I kept it as I was going to put it back on the road but never found enough time and the plate is worth more than the landy as it is OIL xxxx. Local oil delivery company collects these plates for his tankers.
If its an 88 or 90 its not a hicap. The HCPU is on a 110 wheelbase. (some 130s have a version of it.) It has beefed up springs and the rear tub is wider than a normal one, with a full width tailgate, and seperate from the cab, which makes them the perfect donor vehicle for a tipper conversion.
Also did series 3 109s as hi caps.
