40 minutes ago, Mike Hill said:
215 grain round nose.
Norma used to make them but now only Woodleigh does and their factory burned down.
180 grainers with a flat base would also be ok.  This Rifle has Whitworth rifling and been fed a diet of cordite charged rounds. Cordite burns hot and Whitworth rifling has sharper lands so the throat is slightly eroded. Flat based bullets will obturate into the rifling a little bit,boat tails allow some of the gas to wash around the projectile and buffet it,not great for accuracy.
Yeah the cordite is harsh on barrels. A guy at club I was in bought one of the unissued No 4s that came on the market a few years back, he would not put that through it. I see a few lads casting bullets in that weight on some of the forums.
I’ll keep my eyes open.
Kynoch 😂can’t imagine it being cheap mind
Yeah that Kynoch would be dear.
Your mate with the No4 won't hurt it putting cordite through it,he probably just got confused as to why not.
His bore is more at risk from the corrosive primers if he dosnt rinse it with boiling water after shooting old ex mil ammo.
Pretty grim weather today so spent a few hours cleaning up the bedding areas on the Bergara stock “ seen a few guys online having grouping issues due to this” and mounting the picatinny rail, scope and moderator etc. Just need a decent day to get everything where it needs to be and barrel ran in.
7 hours ago, GarethM said:
Does the 20moa angle of dangle make the suppressor visible through the scope?.
I have a 20m of angle 34mm for my .308 but not tried it yet . How far out do you recommend before befitting from using it ? 800yds or more ?
Not as far as I can tell Gareth, I’m running tier one 34mm highs so hopefully it’s no problem.
Morning Stubby, I know you directed that at Gareth but if I may 😌,  in my case I wanted to use a picatinny rail to mount the scope so thought why not 🤷‍♂️. It’s not gonna hit the range much but I’d like to stretch out a bit more than the normal stalking ranges ( I’m no fan of taking long shots on deer or any creature ) if the chance arises, hence sticking on the 20moa rail, I’d say you are on the mark with 800 yards ish, a plus for me is the 20moa is 20 less to dial in as let’s face it the 308 has a fairly looping trajectory compared to some of the new tack driver calibres. I do miss having the opportunity to shoot competitions including PR where 600-1000m was often a start distance, just never seem to have time nowadays as let’s face it shooting is a fairly selfish sport.
I did leave it for @Johnsond, those sorts of distances are a bit outside my acres.
I actually checked two of my longest fields together maxed at 600yards to the barbwire 🙂.
