What else to replace when replacing piston and pot?
josharb87
  • Replies 23
Popular Days
Alright Josh! I'd go for genuine parts. It's a bit of a ball ache changing a pot and piston and takes a bit of time.
The piston rings should come with the piston. Also sometimes you may need to change the crankshaft bearing if there's play in it.
Hi Rob!, Theres a tiny bit of play in the crank, so that'd be a full gasket set needed too, anything else to look for?
Depends where the play is, if it is side to side then don't worry, if the saw has needle crank bearings then don't worry, if it has "up and down play" with roller bearings then worry:001_smile:!!!
Spud
i got it as a non runner, the mesh basket in the carb was full of crud, cleaned out, ran perfect, done near 100 hours, then packed up again-wouldnt idle without reving, then wouldnt start without chokem then died. stripped it today, exhaust port side of cylinder and chamber badly scored.
spud, only slight side to side movement
Nice one thats what i thought.
Anyone got views on non genuine parts? or as im assuming, not worth the bother?
To the non genuine parts Ill only ever get parts what are not extremely to the saw E.g screws little bits and bob Anything that makes the saw run like the piston I would always go genuine
Why would you reject pattern parts?
Have you actually compared genuine and pattern parts?
I have an 026 with a pattern barrel and piston going strong at over a year old and I know of plenty more in that and other models.
