  • Replies 22
these bags just hold a level pallet box of brambly apple logs (9 to 12 inch) 450 logs aprox, had a few sniffs at the price is it worth it!!
You'll need one of the "Log Counters" on Arbtalk to give you a proper answer, but working out at 22p a log and bearing in mind how many you'd get in a small net, I'd say the price is competitive.
The problem may be more in their mind - there is a bit of resistance to spend £100 quid on 1 bag, but if it was the same quantity in two bags they'd probably think it was good value.
Edited by Gareth Dalzell
If your potato box is 64 cubic feet you have 1.8 cubic meters of loose stacked wood - or £55 per cubic meter. Sounds cheap but the customer won't see it that way .:dontknow:
