80 litre tank about 31-33 mpg. so far.
is that on the trip or calculated rich?
havent met anyone that has managed more than 28 yet,,, calculated not trip..
  • Replies 32
Have a look on ebay at the "drakebox" tuning chip. £80 for more power and better consumtion. I did notice a decent return on a long motorway run on my 06 d40.:thumbup1:
If that is a common rail box be very carefull when using them, as they have a habbit of sending the ecu into limp mode due to the ecu thinking it has a fuel leak. I have a DTE box on mine that has 4 different maps on it and 7 power settings per map. The dte box connects between the ecu and the injectors and not between the common rail sensor and the ecu.
Mine has gone into limp before when revved real high to about 4500rpm. Now i know what caused it:thumbup1:. I dont really spend much time at those revs so its only been the once but its good to know what caused it. I had an impending sense of doom when the light came on but it reverted to ok after turning off and re-starting.
look out with your insurance with chipping,,, and also your warranties,, it'll void insurance if you prang and havent told them,
and void warranty if they find it on there too..
