the starting procedure for 300tdi disco in cold weather, ensure all electrical equipment is switched off, turn key to glow plugs, depress clutch pedal, wait a little while, cross your fingers, close your eyes and repeat in your head 'come on-come on', then gently turn the key and hope for the best.. oh and if your name's darren go fetch the battery off the chipper :thumbup:
  • Replies 72
I had a p reg disco 300tdi and it was a great starter, i would head for the plugs first off.
Failing that Darren can you not give it a whif of your super strong hair spray up the air intake......:lol:
That is exactly it. Haha.
Right. We have checked plugs. It's not them. It is fuel starvation from somewhere. There was a fair amount of air in the fuel system so I need to establish where that is coming from.
Bled the air from system and she started like never before.
See again in morning I guess. Will make sure I go check a good while before littleun is due at school though.
Many thanks to Tommer. You are a star.
white smoke from a diesel is fuel starvation- you must have had a weak pump or blocked filters. The filter in the lift pump is faviourite for that one.:001_smile:
We had a new fuel pump fitted and new injectors soon after the alternator refurb. It went from starting white to starting black nad runnin a tad rich uphill. But i thought that if a diesel is running white its a sign of it running far too rich? Thats how Challenger 2 tanks get their smoke screen by dumping unburnt diesel into the exhausts.
Unburnt diesel is black. Check out this tatra truck as is reaches the top of the hill- tatras have the ability to dump shed loads of diesel into the engine for a bit more grunt.......sounds awesome too! Not sure about that with challengers- cant see for a moment how that would work- maybe they arent dumping extra fuel in, but adding something to the fuel?
I thought they had smoke cartridges plastered all over the outside?
[ame=http://www.youtube.com/watch?v=MwSh1v4qbIU]YouTube - Truck Trial Balve 2007 3[/ame]
