I got mine from Amazon for £19.95 - seems to work well.
However, if you are measuring firewood be sure to measure the INSIDE of the log. Split in half and measure the middle of the freshly exposed face in a couple of places to get a feel for the actual moisture level.
Also, measure the middle of your biggest log and a smaller one - if both are the same then they have been well seasoned and reached an equilibrium with the environment in which they were stored. If the small log is significantly lower then they havent been seasoned for long enough....
Hope that helps...
FG
Machine Mart (Kamasa Mini Meter Code 010915961) Price £16.99 + VAT. It even has a temp reading! I have one and it great for firewood and saw planks.
Ditto:thumbup:
Just remember to take it out of your pocket before putting your jacket in the washer. They dont read moisture THAT high:sneaky2:
Hope that helps...
FG
Good post:thumbup1:
All the cheap moisture meters will be fine for firewood but next to useless for seeing how dry planks are! They seem to give inconsistant readings. I went through about 3 cheapies before getting the Delmhorst ones.
