Welding.
Mick Stockbridge
Great, thanks for the replies. Looks like I'll have to up my budget and get this then. What d'ya reckon? Complete package for under £300.
Clarke MIG Welder (Turbo) - 151TE - Machine Mart
Not a bad choice but I would go with this if you can bag it
CEBORA 130 TURBO MIG WELDER on eBay (end time 12-Sep-10 20:05:17 BST)
The model has been around for a long time, tried and tested. It also comes badged up as BOC and Snap on.
  • Replies 42
Some good advice on this thread Mick, those buzz-box stick welders are difficult on most metal, impossible on car bodywork. I gave mine to the scrap man.
A quick and dirty way is to mig it, you get a lot of weld onto it without blowing too many holes and the gasless type save you having to mess with the 5 year bottle rentals for your gas. Mig will make a strong weld and nobody will refuse to MOT a migged repair.
You might be better to hire a welder for a few days, in which case you could get a TIG set, which is Rolls Royce welding and much easier than stick, mig or even gas. With a TIG set you can literally weld a razor blade to a boat anchor, but it is slow. Pro welders will sometimes put the root run, the part of the weld where the metals are thinnest, with a TIG then fill the rest with something faster.
I've got a couple of excellent reference books on welding if you want to borrow them, covering all the methods here and many more ( Explosive paste welding sounds like fun ! )
the 151 t is a cracking little welder
i have used them to build truck bodys cope well upto 3mm strugle abit after that tho
stick is better for the bigger stuff but you will strugle on body panells
as said the cebora 190 are very good
buy biger it will live longer and serve you better
stay cleare of snapoff . utter shite in my opinion
and cold teabags for the arkeye
