no i mean i had 60 dumpy bags full of damp mouldy logs, i then built a bay out of 4 pieces of heras fencing and tipped them all in with the crane, hense why i know a bay holds 60 dumpy bags, not cube, dumpies.:biggrin:
  • Replies 33
tipped in loose. i had split straight into them and they got mouldy so we built the sides and tipped them in:001_smile:
Did the logs lose the mould after tipping out of the dumpy bags?
yes mate, i had started filling the bags before joinging the forum, then once i joined i asked a million questions as you can imagine and i was told they would go mouldy and sure enough they did, with in a month. So tippy tippy and job was a goodin.:thumbup:
I don't know the cost of Heras fencing but I've made cages with pallets on bricks and concrete reinforcing mesh sides. I use wire stays to hold it all in place; you don't need many. Niggles: you need to walk into and out of the cage as you empty it (from one end) and the wire stays can be a pain but stacking logs 8' high is easy and gives you efficient use of ground area.
Joined ... JOINED???? ..... I assumed that you were the founder member and Steve Bullman was just a front man :biggrin:
lol, sorry to disapoint dave, i am a mere member, not even a veteran:blushing::biggrin: I get my heras fencing for a tenner each second hand, the older steel ones are the best:thumbup1:
  • 3 weeks later...
They do take forever to fill though.
HOw do you get on with the saw bench with splitter built in?? Not great i'm presuming seeing you have hydrolic splitter next to it?
