Land Rover Winch
liamjordan
I've had a few winches in the past fitted to Landys but the 12,000 lbs Goodwinch fitted to my current 110 is brilliant:thumbup1:
Very easy to hand pull the cable out and fast/quiet on the pull in.
Just take care when using snatch blocks and slings as the loads can get very large and never stand inside the angle if using a snatch block/pulley to pull around corners or to double the pull!!
  • Replies 55
You bpought one of Dave Bowyers winches??????? Fair play mate. Is it a dressed up superwinch or does he actually have them made?:confused1::001_smile:
. . never stand inside the angle if using a snatch block/pulley to pull around corners or to double the pull!!
ditto that, skidding trees out of a park, had a 90degree redirect, and a timberwolf 150 chipper sitting on the inside angle, redirect sling snapped, the cable whipped into the chipper moving it 10feet across the ground sideways
ive got a winch bumper for sale if you want ace?
When I got mine out of the box it had a KINGONE sticker on it and some spare Goodwinch stickers to put on incase the 'Kingone' hadnt been removed prior to shipping.
My winch is the Goldfish TDS version which I can't fault neither can I fault David Bowyer for price, shipping etc. He also gave me the wireless control that just fits inside the plastic cover under the new 'Goodwinch' sticker.:thumbup:
You can go wireless remote for under 25 quid on the bay
Leave the had wire fitted as a back up and have the convenience of standing wherever you want to.
:thumbup1:
Andy
has anyone got one of the £25 ones fitted. are they ok? im thinking about buying a winch and recognise that its handy to be cutting the tree and doing the winching rather than relying on someone to watch for you to wave your arms etc
I have owned one and fitted two for others and the only bother has been a transmitter that got stood on and fixed with gaffer tape and glue.
It’s mostly solid state gear so there isn’t a lot to go wrong.
You can’t beat cutting and controlling the pull yourself
Andy
Yep, I bought one a while back and the handset is better designed than the original. All works fine.
