hello Fungus, welcome to the site. :001_smile:
Which posts are you refering to specifically ?
Not sure if you noticed, but those last posts are from last year.
The posts by Big Joe.
Gerrit J. Keizer
  • 1 month later...
Someone's been throwing Naan bread around up here in Moray. Guess you might have lots of this but I've no idea. Taken today. Forecast for the tree?
Jim,
No Naan bread, but annual brackets of the "Chicken of the Woods" (Laetiporus sulphureus), which causes a brown rot of the central wood column of the tree. Depending on the tree species (which in this case is ?) and also taking the large wound close to the brackets into consideration, the prognosis for the tree ranges from detrimental on the short run to not that problematic on the long run.
Edited by Fungus
Thanks!
That was my thought having done a bit of reading on here, but being really new to all this I thought I'd check before saying for sure.
Jim,
acer negundo or ash looking at the lichen coverage, which is also a indication of low vigor as its not shedding bark plates fast enough.
Hi, Any help with this fungi spoted on a Yew recently gratefully recieved. New to this so if it is common then please forgive my ignorance. Also what is the possile fate of the Yew and can I advise any work/corrective measures required?
Cheers
Cheers
Steve have a look at the directory link :001_smile:
  • 3 months later...
Ramaria stricta on Salix. Found this in a mobile home park while out surveying the park trees. It is only very small but I wonder if the guys with the experience could tell me the significance please? Will there be a deeper significance below ground/on the roots? :confused1:
