Anyone ever up'ed their trucks with larger wheels/tyres?
My Cabstar is on 205s and I can comfortably go with bigger diameter tyres for not much more than the normal cost of a new set even allowing for suspension movement and mudguard clearance etc
Just an idea given that bigger wheels means increasing mpg
Bigger diameter means longer rolling radius = higher gearing. In theory it should increase mpg as long as engine can cope easily with the higher gearing and you don't have to run it in a lower gear all the time.
205 by what
stick with 205 but find tyres where the second number is bigger
for anyone thats confused on tyre sizes heres an explantion i stole
235 70 R16 109 H
235 mm across the tread
70% of 235 is the wall height
R16 is the wheel diameter in inches
109 is the weight restriction
H is the top rated speed
205 by what
235 70 R16 109 H
235 70 R16 109 H
R = radial type ply construction ("B" = bias ply i.e. cross-ply or it can be missing which also denotes bias ply as in "235 70 B16 109 H" or "235 70 16 109 H")
bigger/larger tyres will make your speedo reading incorrect!normally on a landrover this is about 10% slower ....so watch the speed cameras!
And factor in the speedo inaccuracy when calculating your new mpg
smaller diameter tyres give quicker acceleration & a lower top speed.
bigger diameter tyres give slower acceleration & a higher top speed.
assuming you get the same type tyres (say road tyres) as the ones you have now, you may end up pushing the engine harder to get the same rate of acceleration you're used to which will reduce your mpg.
also if your new tyres are wider it means you'll have a larger surface area in contact with the road which means better grip but also more fiction, hence less mpg.
