Ride on mower lift for cleaning maintenance etc
J.D
  • Replies 25
Alright folks,
What do you use for working under your ride on mowers etc ?
I've had a mare this weekend working on an Etesia hydro 100 evo, I struggled at first ot get the ffing blades of then managed to wedge a woodruff key in the spindle housing, long story short, the deck came off and I fixed the problem, but it took hours and it was pouring down, sunday wasted and all I could use was the ramp on the back of our van to raise the deck to do the work.
Is there a way of doing this preferably not one that burns a hole in me pocket ?
Cheers all
Had this problem last night, one of the guys had hit a rock with the Kubota G23 and sliced the shear bolts on the blade spindles. Not wanting to remove the deck again I lifted the deck to its highest position then got the trolley jack under one side of the back grass box plate and lifted it up to about 30-45 degrees. Locked the blades out with a block of wood and did the first side, torqued up and jack down, then did the same again at the other side. Job done in about 15mins. The G23 does have a great deck lift height to start with though. First time in ages I haven't sworn at a machine when I've been fixing it!:thumbup:
See mo-jack available soon from Oregon see Welcome to Oregon Cutting Systems to see it in the flesh, safe easy and worth the money.
Les
I usually push them up onto their backs so they rest on the part where the grass collector should go. Then rope or chain it to something secure. I did this after seeing a mower maintenance company doing the same thing in their workshop.
  • 3 months later...
