was that your action or just found. Nice skills if it was you. Great shrapnel and after shock.
Cheers, had to rig out some limbs growing over the house before felling it :biggrin:
there's a tractor in the back ground. did you winch/pull it over? or did you just use your wedges. If just the wedges i can understand you wanting to get some weight of the house side.
Woodpicker - it was felled at that height because I like to stand and just drop the saw into the stem at a comfortable height, all the timber was logged.
Mester H - metal fence was removed before felling
Skyhuck, Bareroots - If the tree could have been felled without any climbing it would have been....I dont climb for fun. The limbs were removed from the house side due to the excessive weight and it being unbalanced for felling exactly where we wanted it to go. That small building beneath the tree houses a geo-thermal boiler and processor worth a colossal amount of money - a tractor/bull rope and wedges were used.
Fair enough :001_smile:
