The beginning stages of chipper mounting. I have been maneuvering around, and cannot believe the high functionality the mog maintains, even the the protruding chipper. My counterweight does a great job of counterbalancing the weights as well. Still working on the reverser mount for the front.. Luckily, things are slow, and steady with my activities, and have the time.
Thanks for looking.
ACUF
  • Replies 26
Blimey, that's an overhang. Nice one tho with the hot bucket as well. Do you have to move the front lights/indicators forward too?
Thank you all for the good encouraging words. Yeah, I can't believe the simplicity of operations, even with such a protrusion. At this stage I plan to chip into compost containers, or onto the ground. I will explain this in more detail once I have everything in place. I found that one of the feed wheels / hyd motors is not functioning properly, so another thing to fix.. otherwise, this same day I went and pressure washed the unit and chipper and it looks even better.. now to have it in service!!
Cheers!
ACUF
My method of removing my debris has been utilizing the cities recycling program for brush (bundled), and larger diameter bucked for firewood, which I have given freely to the public.
When I'm finished getting this together, the brush will be chipped into a container of the owners, or into a compost pile, etc. If they don't want the chips left on site, I will process them into 30gal leaf bags, and placed for city recycling.
I was considering a type of bin system, to allow for the self containing of the chips. I thought I could design something that would allow me to blow them over the cab, into a binning system that would be able to tip two ways, etc.
This is way down the line, and will be a very involved design, considering the lift being there..
ACUF
