reading the new BS 3998 and came across this good little piece of advice=
Due to its potentially negative effects, crown reduction should not
usually be carried out in addition to other crown pruning operations,
which would add to the amount of wounding and leaf loss.
NOTE 1 Although crown reduction should not be combined with
systematic crown thinning, it often entails some degree of thinning due
to the selective removal of branches at their points of origin.
Hama= so next time you get handed a spec that advises a thinning as well as a reduction, like ive ALWAYS maintained its BS and not in a good way! so refuse to do it.
Edited by Tony Croft aka hamadryad
So when I used to get a job spec that says 30% reduction and 20% thin of what is left...
Your now telling me this is wrong and not good practice? ;)
your forgetting though about the people who work in LA on public trees where they are TOLD what to do unfortunately
Its not all black and white:001_rolleyes: but yes your right, if you have a choice then i 100% agree:biggrin:
yep, thats EXACTLY what I am saying, no matter who specifies it!
thinning a tree that is being reduced is like wearing a belt and then adding braces:biggrin:
You don't need to tell me mate. Whenever I saw a spec like that I just ignored it and reduced the canopy. Occasionally a bit of a thin if I was twigged in the eye, 3 strike rule and all that.
Which I believe I invented?
Mattheck, Shigo, Bolam....
:001_tt2:
