After a 8" tracked chipper, new.
Any opinions, or suggestions ideally from recent use of new models.
I ideally on build quality, performance, value and warranty/service
Edited by Coconut
5 hours ago, Field Builds said:
Först is known for having an aggressive feed system that really grabs wood, and they offer a great, no-quibble 3-year warranty which is a big plus for service value.
Same as GreenMech then....
Anything anyone would recommend other than a Forst or a Timerwolf/GreenGech(owned by the same company now aren't they?)
Are are newer forsts as unreliable as people make out?
Tbf I think they have shaken out most of the initial issues they had with the Doosan engine on them. Eg relays vibrating loose, radiators failing, bonnet hinge bolts falling out, dashboard/display complete failures, electric throttle failures, oh and the dpf doesn't like it if you talk to it rudely.
