1 hour ago, Tree monkey 1682 said:
Have tried e10 in the chipper, if machines left  (Honda gx390) I still get a fecking gammy carb, pipes then I end up putting a new carb on it after normal fuel,  dunno.if its the local garage but premier fuel still has the same outcome
Over a couple of years I have been given half a dozen four stroke pedestrian mowers that the owners have failed to start after being over wintered. They have been replaced with battery powered ones. All of them had gummed up idle jets.
 I dont know , ive tried genuine carbs and non genuine carbs ,still had issues ,got rid ov the Honda engine on and either replaced them with loncin or Villiers..id love to put standard petrol in them but for the cost of carbs and down time I think il stick  sthil 4 stroke, sometimes thirsty  but easier and no issues with carbs or pipes . Its doing my nut in crap fuel.  2 pulls and its running
I don’t understand anyone still using E10 in any machine.
Is it really worth the cost saving?
It’s shite.
Reuben your situation is baffling.
I know you aren’t some cretin who doesn’t understand machines or mix, so it isn’t user error.
Husky gear is generally pretty good, as most of us know.
Have you been saying nasty things about the government on the internet?
They may have sent an elite hit squad to screw your machines.
It’s shite.
Maybe fuel from a certain garage is dire then,and i should use fuel from a different garage!  But the will be weeks where it doesn't get used ,thats when the damage seems to happen -pipes going brittle and carbs playing up... and in the  sediment bowl is a dubious white grease/lard deposit
Anecdotal evidence of course but my local supermarket petrol 'does the job' but the one with 'Bigger Prices' is far superior - a few more mpg in the car. Could be something in that.
All the base petrol comes from the same refinery of course, but different companies put different additives in to make it their own. Supermarkets are less likely to add so much. Of course small local garage might not sell the quantities as a bigger one - could be something there too.
Huskys are known to use poor quality Orings on the carbs accelerator pump. My cs340 was only a couple months old, only a few tanks through her when the carb failed. Motomix and aspen would have rotted the oring just the same.
