I need a new exhaust for my tracked 150, ones for the trailed one say they don't fit the tracked version, What's the difference? I remember sometime when I looked previously the tracked exhaust was more expensive 🫰🏻
Having owned both, trailed and tracked at the same time, since sold the trailed, is couldn't see any difference other than the trailed one had a stainless sleeve shoved over the top where as my tracked diversion does not.
#edit it is a diesel model
Edited by markieg31
Presumably it's diesel, then any dealer with the engine model.
Or as suggested green plant or similar, but best knowing engine type etc.
 Not 100% sure on the TimberWolf, but on the GreenMech the manifold is Kubota and the downpipe & silencer is GreenMech. Would assume the TW150 silencer would be TimberWolf ordering specific rather than a Kubota engine dealer.
Certainly be armed with engine info (probably V1505) along with chipper serial number :)
Edited by GA Groundcare
Just spoke to a helpful chap at greenplant, standard trailed 150d version is around £300.
The correct one for the tracked job is over £600😳
