3 hours ago, Mick Dempsey said:
What were the two later offerings?
I've had alot of mates run entecs , timberwolfs ,gravely ,tp lindana ,jensen, pezzolato, greenmech , kwickchip .. alot of the tw machines have alloy fans to eject the chip..
The are alot of decent refurbished machines for under that budget ..its knowing what your looking for ...would nt buy tw probably not nor would I buy green mech.
I'd only buy European,  better built like ts,lindana ...the pezzolato I have is alot better built than the current machines .
And like it or not where I didnt come into the career later on in life ive seen machines come and go , all you want is a basic machine that's lightweight,that also you can unjam should it get jammed up...and basic so easy worked on.
Only reason the isn't more European machines is due to a price ..id need to look at what ever I purchase next ..ie spares
But alot of machines are built down to a price now.....
There’s something that doesn’t add up with you.
That post is the post of someone who doesn’t really know much about or has even used a chipper.
My bet is you’re a certain banned member on about his 5th attempt to pass.
hi all thanks for the replies some useful info ..     Im still on the fence which way to go, but going to have to make a decision soon ..
been thinking ..   if the prices of a TW150 was cheaper then id be happy with that, but seems like a lot of money for an old machine , tho I have found someone who sells them fully refurbished ,  Have seen a fair few Forsts now, some scruffy looking ones, but cheaper than the TW230 about the same price as TW150 ..    I have been looking at some TW230 and I prob could stretch to around 10k
Something id like to ask is there much init between petrol and diesel ?  what would you pick and why ..?
thanks ..
Dunno but are there any petrol ones that don't use the B&S EFI engine that lots report problems with?
The petrol Hondas on the 125 and 160 are great. The bigger ones (makes escape me) less proven. A couple of clients with the petrol 280 have had hot starting problems, some vapour locky kind of thing I think. The Briggs EFI gets a pasting from one guy in particular on here but I have heard of others with the same problem.
The Kubota diesel that goes in everything is well proven. Mick said the engine code. 1505?
The bloke in Hartlepool comes across well (been to his workshop) and has a fair amount of stock throughput, suggesting competence. But he’s in Hartlepool. I’ve never found anything else good in Hartlepool. It’s a place of quite extreme indifference.
