I think I've been engaging in bellendery and confused the two measurements on the feeler gauges.
So with a cool head I reset the valves cold then ran it up and reset them warm.
It now runs better but lots of resistance on starting, to the point of snatching the starter cord.
Tick over still a little high with it coughing at times.
Edited by Ty Korrigan
tbh, I’m impressed at you changing the head gasket.
A few years ago you couldn’t change the oil filter on your chipper.
I changed the H gasket on my grinder recently, admittedly with the guidance of my brother on FaceTime periodically, it’s not that easy for guys like us.
Chapeau Stu!
Chapeau Stu!
I struggle to put my shoes on some days Mick 😀
the Honda information sheet I linked to doesn't say about reseting the gaps when warm, it just says
If adjustment is necessary, proceed as follows: a. Hold the rocker arm pivot and loosen the rocker arm pivot lock nut. b. Turn the rocker arm pivot to obtain the specified clearance. c. Retighten the rocker arm pivot lock nut while holding the rocker arm pivot. TORQUE: 10 N·m (1.0 kgf·m, 7 lbt·ft) d. Recheck valve clearance after tightening the rocker arm pivot lock nut.
Not sure if this reseting on a warm engine is the right thing to do?
Anyway, at least it's running.
Chapeau Stu!
Cheers Mick,
Was that the Quad chip back in 2012?
 The oil filter in a nightmare place above the slewring.
It required a home-made 'MouseTrap game' style chute for the oil made from water bottles.
I failed every time to cleanly change the oil.
The first oil change was done by the dealer who too failed and charged us €80 for steam cleaning on top.
Last week I changed the Iveco radiator!
I bought one on offer from AutoDoc for a mere €80 !
Took me under 3 hours not rushing.
I cheated a little and didn't reinstall the plastic McGuff surrounding the radiator.
Saved myself between €600/€900 plus vat
Cheapest quote was a mobile mechanic, highest a verbal quote from Iveco main dealer.
I used your guide thanks but the resetting warm was advice I read elsewhere.
Anyway, I'm going to remeasure the gaps once I've received the fresh rocker cover rubber seal which leaks a little.
   Thanks for posting that guide.
  • 3 weeks later...
Back again.
 I had done 2hrs30min since 'repairing' the engine.
The last stump was on a slope and the machine cut out 3 times so I checked the oil 'Oy Vey, Allah Akbar, Mon Dieu and FFS !' to cover all bases...
Oil level low.
It took 500ml
Ran it up again to finish the last stump but it lacked power and the stump being very fibrous made for a dismal hour or so.
Back home, checked the valve clearances and was surprised to find them well out yet the nuts are tight.
I've reset the valves, it runs fine but now light but obvious dark smoke when throttle opened.
Oil vapour from valve cover is inside the part between carb and air filter.
So I think I will change the engine and strip the old one down this Winter and earn my Boy Scouts tinkering badge.
Meanwhile, I'd like to replace the engine with an electric start version.
I see an option with oil bath filter.
Is this worthwhile or even practical on a grinder?
  Please post your answers either here,        or on a postcard to:
      Multi-Coloured Swap Shop,
          BBC TV Centre,
          London W12 8QT
I would think the oil bath air filter would be a no no due to you needing to use the grinder on slopes etc.
    Have a look at the Chinese Honda copies for a replacement (Lifan etc). About half the price, electric start versions available. Obviously check crankshaft length/diameter before ordering. The foam sleeve that goes over the paper air filter element is an important part of the set up if working in dusty environment. It needs to be dipped in clean oil and squeezed out at regular intervals after washing out in petrol to catch any dust etc. before reaching the paper filter.
