44 minutes ago, Ty Korrigan said:
A rake, a lovely wide plastic rake with a varnished wood handle.
I really wanted a 7.5t Isuzu tipper but Mrs Lee vetoed that as she wants a house instead.
Oh! You find that funny do you?
 Siding with my wife now?
 Bastards, the lot of you...
Edited by Ty Korrigan
  • Haha 5
1 hour ago, Dan Maynard said:
as the Oregon chain it comes with has such big safety bumpers you can barely cut with the bar buried so I had to file them off.
I havent understood the purpose of saftry bumpers, as they would always be lower than the rakers and not touching wood...?
Powdery chips, as would with high rakers?
or does it suck power out of the cut?
@kram They basically stop you from plunge cutting, or they make it very slow and horrible, otherwise you can't tell much of a difference.
It's just not that easy getting a chain that small with the safety bumpers. Chainsawbars.com have some, so they have become the best bet
The are below or in line with the raker when the chains travelling straight, but stick out when it's going round the bar nose. Idea is to reduce chance of kickback, problem is you need the bottom half of the nose to cut for cutting with a buried bar. Or any slightly creative cut in between branches etc. If you take a Stihl 1/4 pitch chain it has bumpers but not high, these Oregon ones are just terrible.
I use 3/8LP full chisel with a carving bar on the 2511, carving bar more because its smaller, lighter and can get into tighter spaces. I prefer it for pruning work and a normal bar for removals.
3/8lp full chisel is the smoothest cutting I have found for a top handle. Smoothest I mean the nicest cut quality and best for nibbling away at the ends of long skinny branches.
With semi chisel on 1/4" I found it can bounce and rip these more than it cuts, the shredded tips look is not good.
With a newish chain, long length cutters, it doesnt like plunge cutting - the cutters going to rub with the small nose radius, slow to do anything with the nose, but it does cut. The top and bottom of bar cut beautifully.
Once the chain is half worn with a few sharpens it should have no problem with plunge cuts.
I was going to try the 2511 bars as I have a spare, on the uc002 but the mounting is too narrow - chain would rub the casing.
Got a few 30mm exits for my 462.
I can’t tig weld anymore so I got my pal who’s starting up himself to do it and he’s made a grand job of it.
Quote
Intersting I thought it would be the opposite maybe gauge has more influence than the  pitch IF the 1/4 is 1.3mm gauge & the 3/8lp is on 1.1mm?
Looking at the jap mak catalogue ^ they have alot of options!
WWW.MAKITA.CO.JP
マキタは、総合電動工具メーカーとして、充電式を含む電動工具、木工機械、エア工具、エンジン式を含む園芸工具を取り...
The rear handle 40v has either 35mL or 42mL petrol eqivalent models  the 42ml is alot heavier-  to heavy imo for the limited  power on battery saws, the 35ml ones look more useful but both lines have the same 1600w motor size listed ( on makita NZ)
Only  idifference I can find is the 42mL take the 40v  8amp batteries the 35ml ones don't fit it not sure  if there  are any other differences.......
Looks like they do the top handle in red, I want!
25ap is 1/4" pitch and 80TXL is speedcut nano.
The top is supposed to be 1400w and the others 1600w, so its hardly worth looking at them. Perhaps in future they will do a bigger motor, dual battery 80v version.
Also I have seen there is a BAP001G adaptor in Japan, to have the heavy batteries on a waste or shoulder strap and much less weight on the tool. 70 quid off amazon.jp so for now I will stick with the light batteries.
