Bought a 3d printer last week, for now, I have been printing tat found online, but will be learning how to design stuff soon.
Seatbelt un bleeper
Climbing felling wedge. Added a hole and scaled it down to fit in the side pocket, fuzzy texture to give it more grip.
It can print some of the better plastics, nylon-cf and PPA, but I will mostly will be using PET and ABS.
  • Thanks 2
For chain sharpening, no problem with files except it gives me sore hands. If the chain has hit something and rolled the chrome, then blunts the file, makes it slow work. I had a cheapy Lidl one, it only managed a few chains before letting the smoke out.
This should make it much faster. Milwaunkee are the only brand doing a decent quality brushless type, and its not cheap at £140 for the set, but should last forever.
WWW.POWERTOOLWORLD.CO.UK
Milwaukee M12 BLROT-0 12v Brushless Rotary Tool 3.2mm Collet Body Only  This M12 BLROT Rotary Tool features a variable speed from 5000 rpm to 27,500...
  • 1 month later...
On 23/07/2025 at 13:26, kram said:
New one today, MP001 tyre pump, £100. No more messing about with cig lighter cables and it should have enough air to seat tyre beads when I swap them myself.
No free battery with these tho.
I've had a slow leak in one tyre for ages and dont check it nearly often enough. This should help..
Turns out this was unreliable shite. The slightest bit of humidity or cold in the air and it refuses to turn on. Sat next to the hall heater, it works. Plan is to send it off for warranty repair and then ebay it.
Its replacement arrived today, far more powerfull, uses Makita 18v batteries, but they do others.
Ordered 28th, 8 days from China. Arrived with 5 bar in the tank !
https://www.amazon.co.uk/dp/B0G1M3J3WH
