This was a nice bar. Emphasis on was. Bit floppy at 28" but don't want a nose heavy 500i.
Looking at a GB solid bar now, great value but possibly a bit of a fatty?
Chainsawbars quoted weights are NOT accurate. I bought the Tsumura as they quoted it as being lighter than the Stihl light bar equivalent. It wasn't.
I've looked at GB for next bar on my 372, reputation seems to be good but heavy but I only want 18". Can't remember who now, there is someone who swears by them on here.
Chris Forestry carries them, wonder if he'd weigh one for you?
Exactly the thought I had. Iro 500g heavier than the Tsu. That's a lot when you're old
Edited by Whoppa Choppa
Are you sure the bar is at fault here and not "user error"? That is a hell of a break. I hope the saw is OK.
One alternative it to get another Tsumura, you now have a spare tip for it.
1 hour ago, woody paul said:
As already said most bars will bend along way before breaking, how did it happen.
Looks a fairly new bar.
I never said the bar was at fault. I was attempting to rescue the trapped saw from an end loaded and barbered oak that had a mind of its own, with the forwarder. Release the compression without damaging the saw head. I wasn't being a vandal and the saw head wasn't deflected at all so the sheer load in the stick did that. I must admit I was a bit surprised. Not exactly the corner-cutter 3000. Being a resin filled bar perhaps they made the steel stronger but much more brittle 🤷
