5 minutes ago, Joe Newton said:
I can't be arsed tonight. Basically thread the rope through the beckett of the pinto and over the pulley and back down. Very similar principle to the rig n wrench.
In essence your groundy can lower stuff that would otherwise need a wrap to a wrap and a half on the bollard.
That’s excellent. Cheers.
3 hours ago, 5thelement said:
I use one of these for self lowering, rated up to 500kg but tested at 800kg, friction easily adjustable or it can be locked off
That's good. Never seen one of them before.  I've been cutting pegs and using them for yrs!
Have you ever tried two in series? Like main point and redirect, both beckethreaded.
12 minutes ago, sime42 said:
Is there a reason for that alternative version of Bowline?
I assume you mean tail outside instead of tail inside. Mainly a hangover from tying into my rock climbing harness like that and that just being how it was easier there. Did also spend several hours one evening wondering whether one way was better than the other and doing a lot of loading and unloading, shaking, bending etc. Tail outside is harder to shake apart if you forget a stopper knot. Not a massive difference but still noticeable and repeatable. I usually use a double fisherman's stopper. Have rigged the proverbial moon on it.
Edited by AHPP
Nice, thanks. Interesting. Just that I read somewhere, (a few places actually I think), that the tail tucked inside the loop version was stronger. Maybe one of those myths that's been passed on unthinkingly over the generations. Or maybe it's seen as being more susceptible to being snagged on the outside, leading to capsize of the knot. Seems unlikely looking at it now, and makes no difference if there's a stopper knot.
