19 minutes ago, 5thelement said:
Because ‘the following thing’ already looks like a LOLER fail.
Probably isn’t as easy to attach/disconnect with freezing wet hands either.
Looks like?
Dude, it's wavy straight out the box... 40kN breaking strength...
(Are LOLERers allowed to fail functional kit because they personally aren't familiar with it? That's bollocks.)
As with literally any carabiner, they are piss easy to open and close as long as you've been shown how to do it...
Edited by peds
3 minutes ago, peds said:
Looks like?
Crack on with what you prefer then.
I have steel ones similar, but mine don’t look like they are already bent out of shape.
But the bent out of shape bit is the point... so you can have the spine against whatever hard surface you've got, but the gate is still available...
I have steel ones similar, too, that also don't look bent... because they are a different product...
I just prefer things, generally, that are midline attachable...
Have you actually used this for rigging down anything substantial?
21 hours ago, 5thelement said:
They are really quick to attach, especially on repetitive jobs, and easy to undo, even when the groundy is a dumbo.
Just watched a few videos about it (it’s called the Hexarope Hands Up). It’s slower than a biner, takes two hands and it can’t also be used as a biner. Dumbos may struggle but they work it out. Plus they may be a dumbo who has previously struggled and worked out a biner. More likely than having seen one of those before. And there’s no advantage in them seeing one for the first time. Trinket section I’m afraid.
Edited by AHPP
I know what it’s called as I have one, I quite like using it, it doesn’t have to be a karabiner, I have plenty of those if I  need them.
Each to their own.
I had high hopes when I got a Safebloc but it got so annoying watching the groundie heaving the rigging rope back up (when used with max friction and the fat rig rope) that is has sat in the rigging bag since.  My kingdom for GRCS though - that is a different beast all together..
I've never got my head around that. Friction on the way down is also friction going back up, unless you can remove the kinks or the wraps from the system...
I'm with you on that, that was my thoughts as well.
