11 minutes ago, GarethM said:
Dumb question, is it more of a problem with summer diesel compared to winter fuel that's usually got a bit of added paraffin to prevent gelling?
I think the problem is exasperated in marine engines due to the high moisture causing a bacterial build up, maybe chippers etc suffer more in Winter due to similar. Does added paraffin in Winter not just lower the freezing point of the fuel?
Edited by 5thelement
Just now, 5thelement said:
I think the problem is exasperated in marine engines due to the high moisture, maybe chippers etc suffer more in Winter due to similar. Does added paraffin in Winter not just lower the freezing point of the fuel?
I get the moisture thing in marine and wet environments especially when the tanks can create condensation.
The added paraffin in winterised diesel, makes it usable to something like -12 Vs -4 for summer.
Always wondered if it helped to kill the bugs that can live in the veg oils added to modern diesel.
As these diesel big killers are just an alcohol based additive from what I've seen on the msds.
I use this, i don’t put it in every tank full, maybe 1 in 3 fills. I think its down to the increased amount of bio thats used these days, its certainly worse these days compared to 10 yrs ago!
I have only had problems with machines left outside and used infrequently.
Ive had no problems since I got a bigger shed and I try to periodically run tanks empty and flush them out with petrol and leave to evaporate. seems to work but Im not an expert.
i now suspect my heating oil has a bug (kerosene) so Im going to flush it out soon.
Diesel doesn't so much freeze but rather waxes dissolved in it precipitate out, this wax then blocks the fuel filters, so in the past the refineries produced a summer grade and a winter grade which had a lower waxing point. I think the same winter grade has been used year round since the 80s.
