13 minutes ago, woody paul said:
Some times that's the only way to get a result, face to face and get to talk to the person you need to.
I can see me parked in front of the dealers front door, chip box raised whilst shouting
"ARE YOU GOING TO GIVE ME A F*****G QUOTE?"
 Ford just got back to me but not with a quote.
 The truck doesn't exist as a stock item anywhere in France and has a delay of 12 months once ordered.
 So that hash is settled.
  • Sad 1
Back jn about 2010 you had the option of a 3.5 or 4.2 tonne gvw transit. As far as I could see the difference was heavier duty rear springs and a slightly higher ratio rear axle
I think most ambulances uprated to 4.2t to take all the weight.
Thinking back I remember that if one added up the permitted axle weights, front and rear, of a standard transit 3.5 it came to 4.2 tonnes so...
Lower ratio I assume you mean? ie Higher gearbox revs for equivalent wheel speed.
No higher back axle ratio; say the standard is 3.5:1 then the 4.2 tonne one would be something like 3.8:1 so the propshaft has to spin a bit more for the same distance but there is more torque at the back wheel for the same torque input by the propshaft to shift the extra load,
2 hours ago, Mark Bolam said:
What’s the legal position over there Stu?
As in do they have a version of ‘O’ licence for over 5t or whatever?
If I use the truck for my own work carrying tools and only the waste I generate then no operators licence required 'FIMO'
However, if I use it to resell logs or chip then I do need one.
