Hi, just looking for a second opinion on this piston. Found that this pistons machining marks appear to have been worn away and there's a large black mark which I'm guessing is the saw running too lean but any advice will be helpful.
  On 20/07/2024 at 13:46, Dan Maynard said:
I'd say yes, but that looks well worn so maybe it should have a new piston/cylinder set rather than just piston.
Expand
Strange thing is the cylinder looks pristine, no scoring or transfer that I've noticed. The saw did look like it'd never been maintained or cleaned at all when I got it
That is going to have plenty of piston slap if you refit it, the carbon fouling is from poor quality oil being used, or far too much of it, so I would be fitting a new piston.
Good. The piston can wear like that but the bore, being much harder, will often be fine and a new piston and ring will restore the compression and decent running.
The black bit on the piston looks like a bit of blow by down to piston wear but use semi or fully synthetic oil on these strato engines, the main bearings will thank you for it.
BTW, when you remove the cylinder, you should always blast the chip and oil away from near the cylinder base to stop it entering the engine. Always the best policy.
Read more
