27 minutes ago, GA Groundcare said:
It’s on pretty much all GreenMech chippers. It helps draw heat away from the engine bay and also adds a bit of airflow to the discharge chamber. Patented to GM!
Only the second hottest chips in arb. Which chipper is it that exhausts through the chute? Schliesing? Bandit? Vermeer?
Quite a few inc these. To be honest makes naff all difference to the temperature of the chip. Timber / chip is only in the flywheel chamber for maybe one second before it’s out the chute.
My safetrack has been fine in the last 300 plus hours I've clocked up and I've chipped a hell of a lot of stuff with it volume wise. No issues due to heat with machine or with the chip at all 😀
17 hours ago, dan blocker said:
If a picture paints a thousand words and it’s as good in the metal as it looks then can’t see anyone being disappointed with your services 👍
We are now going to be displaying the machine at APF on the GreenMech stand. You are more than welcome to come and give it the once over!
Good advertisement for you! All the best for the show 😀
