Back to the truckers hitch, I know there is a version where you twist the bow, if that makes any sense. I never understand why you would or wouldn't do it. Any ideas on why twisting it makes a difference?
The "old" or traditional way to tie what was once known as the lorryman's hitch (because in those days we had lorries not trucks) used half a sheepshank to form the loop for the running part, rather than the slippery half hitch favoured today. In this form it is usually necessary to twist the loop to prevent it collapsing before you can apply tension. This version works well with natural fibre cordage but not with synthetic and has consequently fallen out of favour. Using the slippery half hitch structure avoids the need for the twists but does mean the hitch won't simply shake out when released, which was a feature of the original form.
Edited by Treewolf
  • Thanks 3
Ahh right, that makes sense, thanks.
13 hours ago, Mick Dempsey said:
You make a loop, lay it on the rope.
make a turn round the loop, then (and this is the key) make a second turn INSIDE the first one.
just shake to undo.
IMG_3501.mov
Hang on then, how do you tie it off after you've given it a tug?
This is probably the best video on learning to tie the trucker's hitch, anyway:
Bowline on a bight has to be a must for anyone doing winch assisted fells with a bull rope. Can be easily untied even when pulled on really hard and if the loops are tied evenly the weak point around a shackle is doubled up.
You do at the very least have to show assistants how to untie it afterwards otherwise it's a long wait 😄
And to answer the original question
Bowline
Bowline on a bight
Reef
Clove
Rolling hitch
Slippery hitch
Blakes
Fig 8
Reathreaded fig 8
Alpine butterfly
Fisherman's
Truckers dolly
