45 minutes ago, spudulike said:
Some of those hand painted tiles are both valuable and very collectable...in case you didn't know.
Yup. Got some botanical ones which are nice...
These are hand transfer ones . Got quite a few different ones like this I'm currently working out a table top with....
Lots of others in the shed . Mostly flowers etc.
Edited by Botty Cough
They may be worth £30- 40 each tile if they have a manufacturer on them - seen them on bargain hunt and can go for a decent sum.
I am no expert but worth looking and learning before you make your table.
I like them so will keep them and use them thanks.
Can a mushroomed poll be  peened back in shape abit rather than just remove it all with a grinder?
Or heated up and done I suppose....
I did consider giving it to my farrier.
Depends how much heat is required I guess. Obviously dipping it after makes it stronger.
Being older the metal should be a better quality but I'm kind of thinking leave it as is ,.
It's been well used and I kind of like that
2 hours ago, Steven P said:
older axe should re-shape OK
Yeah it probably will but like I said might leave it with it's brutality.,... It's happy enough by the feel of it.
No serious murders or bludgeoned bones seem to have been achieved...😁
Probably easier just to grind and file the mushrooming back to sort it unless you want that look.
I think your spell check kicked in...It is Brades Co not "Braces"....a decent manufacturer.
The wedge - take a 3mm drill and drill the wedge out bit by bit. You may get lucky and be able to lever it out. There may be a metal wedge in there, nails, screws etc but if you are lucky, once the wedge is removed, the handle will knock off there the slot can be cleaned, a new wedge cut and planed to size then fitted.
As I said, use some PVA wood glue to get a good bond and knock the wedge in good and hard then cut it to size.
