leaf2.jpg.2814f80dd5cadf76b08203a5864a4157.jpgleaf3.jpg.01fcd261a16035a5c2128be54b4144c8.jpg
I have a small tree (about 4 metres high) in my back garden. It's an ever green tree that has small white flowers that come out in autumn and stay out for winter.
The leaves are small and waxy.
I have noticed a section of the leaves have started to turn brown (as seen in the picture), so I am trying to find out what tree it is to try and provide help to it if needed.
I had closer look today and the underside of every leave is absolutely covered with what looks like tiny black insects or dots. Any ideas what these are and if they might be causing the tree to die off?? What can I do?
Thanks in advance.
Edited by Ukelele82
Ignore them.  They won't do any long term harm.  In the warmer months you're likely to be visited by Viburnum Beetle, both the larvae and adults of which cause will far more visible damage but again the plant can deal with them
No.  It happens.  Really don't worry about the thing; they're very resilient as I've said.
I beheaded a pair of overgrown ones last year; the branches were up to 7 or 8ft long and going all over the place so I cut the trunk 3ft from the ground.  The regrowth is strong and much bushier
