That does make a lot of sense... And I think I'll give it some serious consideration.. Takes away all the issues im up against. The only thing I would have to do in addition is upgrade my vehicle to have a better towing capacity. I'm pretty sure I'm always over the legal towing weight. Currently I drive a suzuki vitara ddis 1.9td. I've literally in the last 2 weeks installed a pretty chunky ground anchor and use an Oxford nemesis 19mm un cropable chain and padlock. Not invincible but pretty annoying to a thief.
Un cropable it may be but in the days of battery angle grinders we are in nowt is safe!
Edited by Will C
Bloody autocorrect
14 hours ago, maybelateron said:
I'm pretty sure 7.5T horse boxes used privately are exempt from inspections and O licence other than yearly MOT.
Correct, my last 7.5T living box was exempt, annual MOT was all that was needed. Some folk will say, if it’s got a tacho it needs 6 weekly and O license, it’s nonsense,
True you do need a good towing capacity on the vehicle to use a tipper as the trailer itself will be heavy. Usually a 8x4 or 8x5 tipper will be 2700kg max gross so you get a fair bit of wood in that.
  • 3 weeks later...
On 31/07/2023 at 19:16, Rich1977 said:
Thanks for that.... I've since found out its an iveco eurocargo ml75e17k. Type N2.. Revenue weight 7500kg...
I have actually got an ifor williams trailer 8x5 which is great... But isn't a tipper sadly. Getting some great advice here so far thanks
What is the plated weight of that trailer?
On 31/07/2023 at 19:24, GarethM said:
Don't you need an operator license for 7.5ton and a registered base even if it's personal usage ?.
I know you've the ticket, but aren't councils a bit arsey about something like that parked on your driveway?.
Not for personal use but try convincing them its personal use.
Correct
