Do you mean the brackets for a bucket which might not be the standard euro 8? If so then agri linc is your friend.
If you are after a subframe the arms the loader goes into that is a harder find. New they may still make one. If you want a used one then machinery auctions would be the place to look.
Do you mean head stock on the tractor loader weld on brackets?
I have in the past bought a convertor stock.... that took mine from tanco to euro 8... was 200 quid or so though
It's the subframe I am after to fit to tractor,. Have found a couple of complete loaders in different makes at a good price.
Plan was to just swap loader from one tractor to other if needed.
It's a nice idea, but in all honesty I've never known any farmer actually remove a loader from a tractor.
Dedicated tractor loader or telehandler, everything else is just a tractor.
As long as you've soft ride to soak up the bumps, just keep it on.
Got you now..... maybe jasp wilsons may have some as they generally remove loaders from tractors they told me. All I can think of
Might be a bit pricey but it's brackets and the loader.
WWW.EBAY.CO.UK
Find many great new & used options and get the best deals for Quicke Loader Q65 Valtra Brackets 6 Cylinder at the best...
WWW.GRIBBENTRACTORS.COM
Used Tractor Loader Brackets Lamborghini Zetor
Edited by GarethM
