I found an Ali body from a transit on eBay- cut the steel body off my iveco daily, swapped them over with help from a mate and various bars/levers etc.
welded brackets up in situ, bolted it down then made high sides from box steel and ply. Gave it a few coats of bitumen based paint and this lasted me three years. Took about a week and done for under 1k all in - this was about 10 years ago mind so prices have risen since then
I bought a a transit crew cab flatbed and got it converted tipper  with alloy arb box....the good thing is every thing is new, especially the running gear the alloy box sits...cost about 4k plus vat
I'm a psychopath, I went the other way! I had a renault master with a rotten tipper body. Got a great condition dropside (non tipper) body, from a transit, and fitted that, on my own. Not too complicated to make the mountings work.
Gave the old hydraulic pump and ram to a friend, sold the old (alloy) tipper sides for £100!
Handy little runaround, and the dropside has a swinglift on it, which to me is as handy as a tipper would be. (I know you could fit a swinglift to a tipper anyway....)
  • 2 years later...
1 hour ago, Mark Bolam said:
Kirkland’s in Stoke are good if you don’t mind travelling a bit.
Just dropped my 2nd truck off for them to convert, highly recommended and not too far for you compared to a lot of firms. They’re also 10 mins from a train station, easy return journey and pick up.
Don't be fooled by prices thrown about online/facebook either, half the time it’s false economy as they use cheap thin metal for the subframe, cheap hydraulics, lots of “extras” etc.
I have never spent more than £3600 on a tipper, now on my third truck in 13 years. First two tippers I just used three sheets of ply that I would fold up and tie with old rope at the start of the job. Very versatile set up as you could have you full bed back once tipped off and boards removed. Latest truck came with tool box/locker and a shonky drop side bed on the tipper chassis. I paid a local engineer to make me an aluminium high side body with barn doors had it made slightly narrower than standard body and it has  definitely helped it fit in places I wouldn't have other wise. Cost £2500. Tipping gear was already present. Had three years out of it so far. Van engine is a little poorly but still limping on, aspirations of swapping body over onto a mk8 transit if I can't sort current tranny.Screenshot_20251223-104923.png.1601e061c8c6d7cf7b1e118f53a7fe4a.png
Edited by markieg31
