Wondering if anyone knows what this saw is, its a Stiga SP386, but
for its advertised cc 's it seems to cut like a bigger saw.
The Muffler looks to have the same mounting pattern as a Makita EA4300 / Dolmar 421
but not exact same muffler.
Does anyone know if this is a Makita or Dolmar in disguise, is it a split case or plastic clam.
Here is it being repaired then used,
Quote
Would be nice if stiga carried on making the dolmar/makita saws in disguise.
But that stiga spec is only 1.6kw?
Maruyama had some red dolmars but stiga seems less likely as not jp based?
WWW-MARUYAMA-PL.TRANSLATE.GOOG
Profesjonalna, najwyższej jakości japońska pilarka spalinowa cenionej na świecie marki Maruyama. Mocna i wydajna...
Stiga was a Swedish firm, probably still is but apparently the saws are made in Italy so most likely nothing to do with Dolmar or Makita.
If it is only 1.6kw then it sure cuts above its size, near the end of the video he cross cuts with it,
and it held up very well.
Spot the difference?
 CRANKCASE ASSY shape  looks the same?
Here:
Stiga
WWW.WORLDOFMOWERS.CO.UK
Engine 2 assembly details for Stiga SP 386 [240381602-S17] 2018 model
Makita
https://cdn.makitatools.com/apps/cms/doc/prod/EA4/3544ffb1-6a12-41f4-b2a6-db0e986edb46_EA4300F40B_EA4300FR_PS-421_PB_Rev_7.pdf
It sure does look the same.
If that is the parts diagram for the Stiga 386 then it looks a lot like the Makita engine.
But then it also looks like them green Active saws made in Italy, too well made to be
an efco or emack or oleo mac
Edited by Echo
Its a generic chinese saw made to stiga spec. The recoil handle is a giveaway to start with, and then it goes on from there. The saw comes supplied with a file, which is always a dead giveaway its chinese sourced to those in the know. The crankcase alloy casting is most definitely chinese.
Just looks like a sharp saw to me in green oak, it’s not tearing through… even a plastic clam engined saw will cut well with a decent chain on.
It is missing the generic alloy balcony at the back where the filter sits on
every china saw I have seen, they try and disguise it with paint usually or plastic
comes down, its not on that saw.
In any event, from what I can see, every year the model changes, so buying the same
model No is no guarantee you wouldn't get a clam shell instead.
