16 minutes ago, kerryp said:
So is that 3 to 3.5 to a builders bulk bag cheers
A builders bulk bag is typically around two thirds of a cubic meter.
A loose tipped metre cube could with care be tight stacked into a builders bag though.
I've just recently stacked a two cubic metre load that was tipped into a 1.6 m3 trailer (so piled up) and once tight stacked in the wood shed it occupied 1.3m3.
On 21/12/2022 at 23:28, kerryp said:
Apologies if it's already been done but could some one tell me how many barrow bags per cube chopped wood cheers
If your bags are the same size as these, then they are 0.2 m3, which is 5 bags to the cube.
SACKMARKET.CO.UK
Heavy duty reuseable Barrow Bags for Logs with Vented sides 45x45x95cm high (approx) 4 x 20cm high lifting loops...
